eXtreme Power Supply Calculator Update
mnemonik23
49
The following changes were made in Lite and Pro versions:
Graphics Cards:
- added ATI HD 2900 XT 1GB GDDR4
- added ATI Radeon X1950 XT
- added NVIDIA GeForce 8300 GS
- added NVIDIA GeForce 8400 GS
CPUs:
Socket AM2
- added AMD Athlon X2 BE-2300 1900 MHz Brisbane
- added AMD Athlon X2 BE-2350 2100 MHz Brisbane
Socket 939
- added AMD Opteron 185 2600 MHz Denmark
- added Intel Celeron 420 1600 MHz Conroe-L
- added Intel Celeron 430 1800 MHz Conroe-L
- added Intel Celeron 440 2000 MHz Conroe-L
Socket LGA775
- added Intel Xeon 3040 1860 MHz Conroe
- added Intel Xeon 3050 2130 MHz Conroe
- added Intel Xeon X3210 B3 2133 MHz Kentsfield
- added Intel Xeon X3220 B3 2400 MHz Kentsfield
- added Intel Xeon X3210 G0 2133 MHz Kentsfield
- added Intel Xeon X3220 G0 2400 MHz Kentsfield
- added Intel Xeon X3230 2667 MHz Kentsfield
Socket 771
- added Intel Xeon E5335 2000 MHz Clovertown
- added Intel Xeon X5365 3000 MHz Clovertown
- added Intel Xeon LV 5128 1866 MHz Woodcrest
- added Intel Xeon LV 5138 2133 MHz Woodcrest
- added Intel Xeon LV 5148 2333 MHz Woodcrest
- added Intel Xeon LV L5310 1600 MHz Clovertown
- added Intel Xeon LV L5320 1866 MHz Clovertown
mnemonik23
49
RAM
- added ability to select FB DIMMs
- added ability to select up to 32 sticks of RAM
PCI cards
- added TV Tuner Satelite reception card
- added TV Tuner Cable reception card
- added TV Tuner Antenna reception card
Video Cards
- added NVIDIA GeForce FX 5500
- added NVIDIA GeForce 8600 GT 1024MB
- added ATI Radeon HD 2400 Pro 128MB
- added ATI Radeon HD 2400 Pro 256MB
- added ATI Radeon HD 2400 Pro 512MB
- added ATI Radeon HD 2400 XT
- added ATI Radeon HD 2600 Pro 256MB
- added ATI Radeon HD 2600 Pro 512MB
- added ATI Radeon HD 2600 XT 256MB
- added ATI Radeon HD 2600 XT 512MB
- added ATI FireGL V3600
- added ATI FireGL V5600
- added ATI FireGL V7600
- added ATI FireGL V8600
- added ATI FireGL V8650
CPUs
- added Intel Xeon E5330 2133 MHz Clovertown
- added Intel Xeon E5340 2400 MHz Clovertown
- added Intel Xeon E5350 2667 MHz Clovertown
- added Intel Xeon LV L5335 2000 MHz Clovertown
- added Intel Xeon E7210 2400 MHz Tigerton
- added Intel Xeon E7220 2933 MHz Tigerton
- added Intel Xeon E7310 1600 MHz Tigerton
- added Intel Xeon E7320 2133 MHz Tigerton
- added Intel Xeon E7330 2400 MHz Tigerton
- added Intel Xeon E7340 2400 MHz Tigerton
- added Intel Xeon X7350 2933 MHz Tigerton
- added Intel Xeon LV L7345 1866 MHz Tigerton
- added Opteron 1220 2800 MHz Santa Ana
- added Opteron 1222 3000 MHz Santa Ana
- added Opteron 1222 SE 3000 MHz Santa Ana
- added Opteron 1210 HE 1800 MHz Santa Ana
- added Opteron 1212 HE 2000 MHz Santa Ana
- added Opteron 1214 HE 2200 MHz Santa Ana
- added Opteron 1216 HE 2400 MHz Santa Ana
- added Opteron 1218 HE 2600 MHz Santa Ana
- added Opteron 2218 HE 2600 MHz Santa Rosa
- added Opteron 2220 2800 MHz Santa Rosa
- added Opteron 2222 3000 MHz Santa Rosa
- added Opteron 2222 SE 3000 MHz Santa Rosa
- added Opteron 2224 SE 3200 MHz Santa Rosa
- added Opteron 8218 HE 2600 MHz Santa Rosa
- added Opteron 8220 2800 MHz Santa Rosa
- added Opteron 8222 3000 MHz Santa Rosa
- added Opteron 8222 SE 3000 MHz Santa Rosa
- added Opteron 8224 SE 3200 MHz Santa Rosa
- added Opteron 2344 HE 1700 MHz Barcelona
- added Opteron 2346 HE 1800 MHz Barcelona
- added Opteron 2347 1900 MHz Barcelona
- added Opteron 2347 HE 1900 MHz Barcelona
- added Opteron 2350 2000 MHz Barcelona
- added Opteron 8346 HE 1800 MHz Barcelona
- added Opteron 8347 1900 MHz Barcelona
- added Opteron 8347 HE 1900 MHz Barcelona
- added Opteron 8350 2000 MHz Barcelona
- added AMD Athlon 64 X2 6400+ 3200 MHz AM2 Windsor
http://www.extreme.outervision.com/psucalculator.jsp
JEDIYoda
33,986
3,321
I dare say most if not ALL power supply calculators are highly inaccurate!!
I have yet to find a power supply calculator that is accurate even remotely!!
Always take with a grain of salt what these calculators will say you need!!
Peace!!
tomoyo
418
Sadly this calculator still overmeasures my computer by about 150 watts. That's not a very precise way to find the size of your psu that you need.
JEDIYoda
33,986
3,321
I have seen them go iether way.......under and over..
John
Moderator Emeritus<br>Elite Member
Are you selecting single or dual processor?
mnemonik23
49
Sure, there is no way to make it 100% accurate because it is based on component groups, not individual components (except CPU, and Video Cards) and it was designed to give you as close estimate as possible.
BUT: you are saying it over measures your computer. Let me ask you this. Can you provide a 100% or even 85% load of ALL, I repeat ALL of your computer components? I don't think so, that?s why you see lower wattage if you, say, use kill-a-watt monitor or a similar tool. And that's why you have all necessary adjustments in the Calculator to come up wit closest result as possible.
Again, do not expect the Calculator to be 100% accurate - it's impossible! Unless we enter all known computer components individually in our database. But in this case it will probably die in a few months as all other previous calculators that made an attempt to list individual components and found it un-maintainable.
Regards,
mnemonik23
SparkyJJO
13,357
7
I use it more as to get a rough estimate, just gives me an idea of what capacity PSU I should be looking at.
I found the CPU power calculator pretty cool - didn't realize my opteron 165 dumps almost 180W of heat :Q
twinkdogg
19
I just did a calc for my new system and for some reason this just seems a little high:
System Type: Quad Processor
Motherboard: High End - Desktop (Abit IP5 Pro)
CPU: Intel Core 2 Quad Q6600 2400 MHz Kentsfield
Overclocked: 3000 MHz, 1.4 V
CPU Utilization (TDP): 85% TDP
RAM: 4 Sticks DDR2 SDRAM (Crucial Ballistix Tracers DDR2-800)
Video Card 1: NVIDIA GeForce 8800 GTS 640MB
IDE HDD 7200 rpm: 1 HDD
SATA HDD: 3 HDDs
CD-RW Drive: 1 Drive
DVD-RW/DVD+RW Drive: 1 Drive
Floppy Drive: 1 Drive
Sound Blaster - All Models: Yes
PCI IDE Card: Yes
PCI-e x1 Card: 1 Card
PCI-e x4 Card: 1 Card
USB: 4 Devices
IEEE-1394 FireWire: 1 Device
Fans
LED: 5 Fans 92mm; 1 Fan 120mm;
Cold Cathodes: 2 Cathodes
Keyboard and mouse: Yes
System Load: 90 %
Recommended Wattage: 884 Watts
Recommended Amperage:
+3.3V +5V +12V
13.6 A 18.3 A 62.3 A
And this was without using the capacitor aging feature. If I add that at 30% is jumps up to 1149 watt PSU recommendation. I plan on keeping my PSU for at least 3-4yrs.
Do you all think this seems high? Is it unrealistic to use a 90% system load for your calculation?
twinkdogg
19
What cards are those???
The x1 will be a TV capture card like the WinTV-HVR-1800. I actually haven't decided on that one just yet. It may end up being a PCI card.
The x4 will eventually be an Adaptec 3805 sata raid card.
SparkyJJO
13,357
7
Originally posted by: saiga6360
Shouldn't that be Single Processor?
Ding, yup I just saw that now that you mentioned it. Single processor, 4 cores, must have thought it was 4 processors. wow 4 quads would be sweet :D
saiga6360
61
Yeah, I made the same mistake before and nearly gave myself a heart attack since I already ordered a 520W PSU and it gave me a result of 612W.
twinkdogg
19
Doh!! I had it in my head that the setting that I needed was quad processor b/c I was running a quad core. I didn't even read the note below the System Type selection that clearly states "Attention: Dual or Quad Core CPUs are Single Processors." LMAO!! Damn ADD! :) Thank you guys for recognizing that.
Ok, now this is more like it. I'm getting 527w without any capacitor aging and 686w with a 30% capacitor aging setting. You think my Antec TruePower 430w should get me by for the time being?
I've been looking at getting the Thermaltake W0116RU 750w for a good PSU that will last me a few years. I also like the Enermax Infiniti 720 too but it's a little pricey as there is no rebates on it currently.
ArchAngel777
5,223
61
I made the same mistake... Maybe the disclaimer should be in bold with an exclamation point... I totally read singl, dual and quad as 'core' rather than CPU.
That changed my values quite a bit... In what I would consider a good 'guestimate'.
SparkyJJO
13,357
7
I wouldn't try it. Might work ok at idle but load it up and I'd fully expect OCP to kick in.
Just get a good PSU right off the bat.
mnemonik23
49
Graphics Cards
- added NVIDIA GeForce 8800 GT
- added ATI FireGL V3300
- added AATI FireGL V3350
CPUs
- added AMD Athlon XP 2900+ 2000 MHz Barton
Water Cooling Kits
- added Koolance PC4-1000
- added Koolance RP-1000
Water Pumps
- added Danger Den DD-CPX1
- added D-TEK DDC-3.1
- added D-TEK DDC-3.2
- added Gigabyte DP-600
- added Koolance PMP-400
- added Koolance PMP-450
mnemonik23
49
Graphics Cards
- added ATI Radeon HD 2900 Pro 512MB
CPUs
- added Intel Core 2 Extreme QX9650 3000 MHz Yorkfield XE
- added Intel Core 2 Duo E6540 2333 MHz Conroe
- added Intel Core 2 Duo E4500 2200 MHz Allendale
- added Intel Core 2 Duo E4600 2400 MHz Allendale
- added Intel Xeon E5205 1866 MHz Wolfdale-DP
- added Intel Xeon X5260 3333 MHz Wolfdale-DP
- added Intel Xeon X5272 3400 MHz Wolfdale-DP
- added Intel Xeon E5405 2000 MHz Harpertown
- added Intel Xeon E5410 2333 MHz Harpertown
- added Intel Xeon E5420 2500 MHz Harpertown
- added Intel Xeon E5430 2667 MHz Harpertown
- added Intel Xeon E5440 2833 MHz Harpertown
- added Intel Xeon E5450 3000 MHz Harpertown
- added Intel Xeon X5450 3000 MHz Harpertown
- added Intel Xeon X5460 3166 MHz Harpertown
- added Intel Xeon E5462 2800 MHz Harpertown
- added Intel Xeon E5472 3000 MHz Harpertown
- added Intel Xeon X5472 3000 MHz Harpertown
- added Intel Xeon X5482 3200 MHz Harpertown
- added Intel Xeon X5365 G0 3000 MHz Clovertown
- added Intel Xeon 3065 2333 MHz Conroe
- added Intel Xeon 3075 2667 MHz Conroe
- added Intel Xeon 3085 3000 MHz Conroe
- added Intel Pentium Dual-Core E2180 2000 MHz Allendale
- added Intel Pentium Dual-Core E2200 2200 MHz Allendale
- added Intel Celeron 220 1200 MHz Conroe-L
- added AMD Athlon X2 BE-2400 2300 MHz Brisbane
mnemonik23
49
The following changes were made:
Graphics Cards:
- added NVIDIA GeForce 8800 GT 256MB
- added NVIDIA GeForce 8800 GTS 512MB
- added ATI Radeon HD 3850 256MB
- added ATI Radeon HD 3850 512MB
- added ATI Radeon HD 3870
CPUs:
- added Intel Core 2 Duo E8200 2667 MHz Wolfdale
- added Intel Core 2 Duo E8400 3000 MHz Wolfdale
- added Intel Core 2 Duo E8500 3166 MHz Wolfdale
- added Intel Core 2 Quad Q9550 2833 MHz Yorkfield
- added Intel Core 2 Quad Q9450 2667 MHz Yorkfield
- added Intel Core 2 Quad Q9300 2500 MHz Yorkfield
- added AMD Phenom 9500 2200 MHz Agena
- added AMD Phenom 9550 2200 MHz Agena
- added AMD Phenom 9600 2300 MHz Agena
- added AMD Phenom 9650 2300 MHz Agena
- added AMD Phenom 9700 2400 MHz Agena
- added AMD Phenom 9900 2600 MHz Agena
mnemonik23
49
Graphics Cards:
- added NVIDIA GeForce 9600 GT
- added NVIDIA GeForce 8800 GT 1024MB
- added ATI Radeon HD 3870 X2
CPUs:
- added Intel Core 2 Duo E8190 2667 MHz Wolfdale
- added Intel Celeron E1200 1600 MHz Allendale
- added Intel Xeon E3110 3000 MHz Wolfdale
- added AMD Athlon X2 4850e 2500 MHz
- added AMD Sempron 64 3800+ 2200 MHz AM2 Manilla
- added AMD Sempron 64 3000+ EE 1600 MHz AM2 Manilla
- added AMD Sempron 64 3200+ EE 1800 MHz AM2 Manilla
- added AMD Sempron 64 3400+ EE 1800 MHz AM2 Manilla
- added AMD Sempron 64 3500+ EE 2000 MHz AM2 Manilla
- added AMD Sempron 64 LE-1100 1900 MHz AM2 Sparta
- added AMD Sempron 64 LE-1150 2000 MHz AM2 Sparta
- added AMD Sempron 64 LE-1200 2100 MHz AM2 Sparta
- added AMD Sempron 64 LE-1250 2200 MHz AM2 Sparta
- added AMD Sempron 64 LE-1300 2300 MHz AM2 Sparta
Pro version:
Added ability to select 3-Way SLI and Quad CrossFire X in Pro version.
eXtreme Power Supply Calculator Lite
mnemonik23
49
Sockets
- added Socket LGA1366
- added Socket Micro-FCBGA
CPUs
- added Intel Core i7 920 2667 MHz Bloomfield
- added Intel Core i7 940 2933 MHz Bloomfield
- added Intel Core i7 965 3200 MHz Bloomfield XE
- added Intel Atom 230 1600 MHz Diamondville
- added Intel Atom 330 1600 MHz Diamondville
Graphics Cards
- fixed NVIDIA GeForce 6200 power consumption data
Watercooling
- added Aqua Computer Aquastream XT Ultra USB Eheim pump
- added XSPC X2O 150 pump
- added XSPC X2O 200 pump
- added XSPC X2O 750 pump
OCGuy
27,224
37
Hmmm....with my system below with 3 HDs and a 2nd 280 on the way says 598W. I guess I will be OK with the Corsair 750TX I have on the way.
Why do people always say 1000W or 1200W automatically? I know it is better to run at a lesser % of max output, but some people are rediculous.
