Extreme mouse click sensisivity
juzzlukin
37
Windows 10 pro Build 15063.850 (1703/RS2)
Logitech m310 wireless mouse
I'd like to discover if this is a mouse related or windows related.
Basically, for several months now it's like sometimes my mouse acts like I have it set to "Single Click" under the "Click items as follows". I'll barely click on folder a link and it will react very suddenly..
Sometimes the effects seem more extreme than others.
I've tried adjusting the mouse settings to no effect as far a this problem is concerned
This isn't the same problem a lot of people have complained of over the years where trying to select a sub file or folder causes a sudden horizontal scroll to the right. I've always had that problem as well, but this mouse behavior I'm describing now is quite different.
I have the latest graphics driver from windows update, but this Intel has a later one, but I'd rather not update it unless it is necessary.
As you can see I don't have the Fall Creators update. It created havoc for me when I installed it months ago, but maybe it would help now??
daveybrat
5,804
1,015
There's no reason not to install the Creator's Fall Update 1709. I've installed it on dozens of customer's computers with no issues. It might even cure you issues.
fastamdman
1,335
70
Do a fresh windows install, update to the latest build of windows, update all drivers to the latest drivers. If that doesn't solve your problem, please report back.
juzzlukin
37
Thanks for all the responses.
The mouse was broke.:)
I have two m310 mice. Turns out both were faulty. One was giving me wheel scroll trouble, and I was sent a new one on 1/9.
As soon as I tried it, and it worked perfectly, not only the wheel, but no bad mouse click behavior, It was clear the issue I described here about the other mouse was due to the mouse, not a system thing.
Who knew?
Thanks again.
