- May 22, 2004
- 2,179
- 0
- 0
http://www.abc.net.au/science/news/stories/s1185666.htm
Japanese scientists say they have tackled one of the last frontiers of semiconductor technology, environments where electronic devices have to run at high power, in fierce heat or at lethal doses of radiation.
They say their new semiconductor, which is based on silicon carbide (SiC), may one day be used to develop cleaner and more powerful jets and cars, clearer radio and telephone communications, and send spacecraft on missions previously thought too dangerous.
The researchers, led by Kazumasa Takatori of Toyota Central R&D Labs of Japan, published their new method of growing SiC crystals in today's issue of the journal Nature.
They say their method could make larger and more reliable wafers of the material, making them cheaper and more useful than before.
Conventional computer chips comprise a thin slice of silicon, which is made by cooling pure, molten silicon in such a way that, as the fiery drop solidifies, a crystal grows in a certain direction.
Ground into a wafer and then cunningly doped with chemicals to tease out conductive circuitry, the silicon can then be etched to house millions of electronic components.
But the problem is that silicon devices are very sensitive to heat.
They can malfunction in high temperatures, even from heat generated by their own circuitry, a factor that requires fans or other gadgets to cool them down, limiting their future miniaturisation.
Silcon carbide crystals were hard to grow well
Silicon carbide has interested scientists since the early years of semiconductors in the 1950s as it is extremely hard and highly resistant to heat.
But SiC is hard to manufacture in large, high-quality crystals. The crystals are prone to flaws called micropipes, microscopic tubes that damage or weaken the circuitry and make the chip vulnerable to failure.
Now, the Japanese researchers say they have overcome that hitch thanks to a new way of growing SiC crystals.
The researchers grew the crystals in several different stages. At each stage, the crystal was carefully rotated so that the solidifying compound crystallised on the best, least-blemished face.
By building up the crystal layer by layer, ingots of SiC, the little bricks from which wafers are sliced were "virtually dislocation-free", the researchers said.
"These results are spectacular," said French materials physicist Dr Roland Madar, from the Institut National Polytechnique in Grenoble, when he assessed the work.
"The [layering] process is a major innovation in materials science. Silicon carbide has become, at last, a contender for silicon's crown."
Hotter, faster, more reliable
Among the potential outlets for SiC semiconductors are extreme environments where they are required to operate at high power or withstand high temperatures.
These include microwave communications, radar and high-definition TV transmitters, and also jet and car engines where sophisticated sensors are in demand to monitor performance and curb excess fuel consumption and pollution as much as possible.
Previous research has already shown that even at red-hot temperatures as high as 650°C SiC devices can work unperturbed and without cooling.
They may also be used in space exploration, allowing the creation of robot spacecraft that would carry a bigger payload and go on more ambitious missions.
SiC components could withstand the scorching heat of Venus or operations near the Sun.
As for deep-space missions, where nuclear power will be needed for the craft, radiation-hardened SiC devices would reduce the shielding needed to protect reactor control electronics, saving weight.
