I'm not a big expert in cars although I used to love reading R&T, C&D and all the other magazines. My dad is hanging onto his 1991 Buick LeSabre Limited. He loves this car for some reason (he's convinced it's a good car because it was the last metal bodied LeSabre...not sure if that's true!).
Anyhow, it'll be replaced after winter. Up here in Toronto though with the temperatures varying from -40 degrees C (with windchill considered) all the way to 15 degrees C between November and March, this can really take a toll on a car.
Let me cut to the case. The car doesn't have nearly as much torque as it did. I'm convinced the transmission is on its last leg. It seems as if the transmission timing is off. First gear gives horrible torque and there's a "thud" when you change into second gear where the car seems to pick up torque. On the highway, the transmission doesn't seem to switch into overdrive. So passing has become next to impossible unless you plan well ahead. Also, sometimes even getting onto the highway is a chore, as the car starts lagging and the gears won't change...so it seems like I stay in 3rd or 4th for a REALLY long time where the car stuggles to get past 80 km/h...and then that "thud" happens and everything seems fine again.
Anybody know what the problem might be and what the solution to it would be? Any help would be appreciated.
Thanks,
-GL
Thanks,
-GL
