ScissorClaw
<P class=MsoNormal style="MARGIN: 0in 0in 0pt"><FONT size=3><FONT face="Times New Roman">I have a P4C800 with a SERIOUS overheating problem. Right now, or rather when the computer was on, it was 88 CELSIUS. About 2 hours ago it was at 44 degrees under full load (folding@home in the background) and 35 Celsius idle. Yesterday it was showing up as 167 degrees CELSIUS! Yes, I am yelling on the word CELSIUS! I checked to make sure that it was set to Celsius and not Fahrenheit, and in fact it was set correctly. I checked the temp in Hmonitor and MB monitor and ASUS probe and they are all giving me the same figures. Well, after I saw the 167 yesterday, I broke it down completely. I'm using an MCX4000 with a fan that may not be the best. It runs at only 2500 RPM and it's CFM is probably a tad low around 25. However, I placed a 120mm on there when it started to overheat yesterday, and it didn't make a dent in the temp. So as I was saying, I broke it down, replied AS III and re-assembled. I've been building computers for a little over a year now and I'm pretty sure I know the correct amount of AS to put on there, so I don't think it is that. The HS is on nice and tight. I had the sane HS and Fan on an Intel 865PERL up until Monday with NO temp problems whatsoever. I have a thermal probe that came with the case. Unfortunately, I think it is busted because it displays L which means the temp is so low that it is not worth reporting. On previous computer, it usually kicked in at about 35 degrees Celsius. Of course, the diode on the chip could be busted as well. I'm kinda at a loss. This weekend I am possibly going to buy a new HS and fan. Maybe just a new fan, possibly a 92mm Tornado perhaps. Everything in the BIOS is set at default, no overclocking going on, yet 🙂</FONT></FONT>
<P class=MsoNormal style="MARGIN: 0in 0in 0pt"><FONT size=3><FONT face="Times New Roman">Anybody have any idea why the temp is going up then down then up...yada yada yada...Nothing has changed with the computer to make it go up and down like this. Quite perplexing I might say.
</FONT></FONT>
</FONT></FONT>
