azntiger0586
i have a generic case with 1 front intake, 1 side intake, and 1 rear exhaust.
my power supply is a 450antec with a fan one on side and another fan in the rear.
the power supply is mounted within the case towards the top so that the side fan(intake) is facing down and the rear(exhaust) is facing towards the back.
i notice that the rear exhaust fan of the power supply is removing hot air slowly (slower then my 2600rpm case exhaust). I want to increase the speed of the psu exhuast, how would i go about doing this? should i just add a stronger fan and screw it to the back of the psu? or should i replace the fan inside of the psu? if i replace the fan of the cpu with a 2600rpm 80mm fan, would it run at 2600rpm? or would it run at something else.
my chasis temp is 30c and cpu is 45c. i know the temps are good, but cooler is better 😀
Many Thanks.
Many Thanks.
