External TV Tuner
kelvin1704
869
Currently looking for a external TV tuner ability for my laptop, does anyone know any good product that u might have use before?
I actually has just purchase the Avermedia USB TV tuner, the quality does not meet my expectation. Wanted to change, but doesn't know what to change... probably all other are the same anyway.. please advice.
bigshooter
2,157
Originally posted by: gotsmack
tv tuners suck, they get no reception unless you have cable or the dish.
or a good antenna. Of course you're not going to get good reception off a 1/4" receptor off the back of the card. You might need some old rabbit ears or something, but I don't see him mentioning that he doesn't have cable.
kelvin1704
869
no no no. I am going to connect a DVD player to it. Actually its for a live video input for a function that I am going to have.
Anyone has any recommendation?
gotsmack
5,768
I bought a $50 powered antenna and I only get 1 station, barely. I've owned 3 tv tuners.
gotsmack
5,768
viewsonic makes a set top tv tuner thing. I own it and it is pretty good for hooking up my playstation to the monitor.
kelvin1704
869
Does the viewsonic looks crips?
U see, the avermedia that i bought doesn't. It looks wash out even the connection its from a DVD player.
kelvin1704
869
I mean clear.
Because the avermedia that I had doesn't seem clear enough. Its even worst than a TV.
kelvin1704
869
alright, avermedia is definately out of the question after I use it in my 9000 people function.
anyone has any recommendation? please...
Is there a fire wire TV tuner?
I do not mind its external or internal, as long as it works.
Jeff7
41,596
20
I can just see it now - a laptop with a pair of rabbit ears on top of it. :D
iohmssi
16
I own a Nextvision N6 made by Viewsonic that features component input. It looks great on a cable signal or antenna, but dvd's dont look too hot even with a progressive scan dvd player. Digital signals are going to look blocky and pixilated on a high resolution monitor. But it doesnt have a way to input a signal for capture if thats what you are looking for, its just a input to the monitor so it might not work with a laptop. Not sure if this helps, but its all ive got.
Chadder007
7,560
I replied a while back about a Pinnecle USB 2.0 tuner that came out recently. It features MPEG2 compression ....it may also have better video quality since it has a bigger bus to push the video through. USB 1.1 doesn't really have the bandwidth needed for quality video. Does your system feature 2.0?
Here is the link....
http://www.pinnaclesys.com/ProductPage.asp?Product_ID=1008&Langue_ID=7
Also keep in mind that ATI is coming out with a new chipset that allows Digital Cable and Satelite tuning. Im not sure how far along this is though.
kelvin1704
869
Yes, I do have USB2.0
ATI is coming out? I wonder when....
dose any of u use the ATI all in wonder 9700 pro before? it does has a TV tuner, I wonder how it do compare to all these USB stuff..
HomerSapien
1,756
If you are going to play dvds on it, why not get an external firewire dvd player. If you just want the input connections, get a dazzle video capture. They have s-video, rca, etc and some have firewire. You should be able to play video through that.
If you are trying to save a few bucs by going the tv card route and i am assuming a dvd player meant for tvs, you might be out of luck in hoping to get dvd quality.
If you already have an internal dvd player in another computer, just take it out and get a firewire/usb2.0 enclosure and it will work fine.
Chadder007
7,560
If you got the AIW 9700 pro....it would be definately better compared to USB (just not sure about compared to USB 2.0 stuff). Of course, your asking about a laptop right? No AIW's for laptops that I know of have been made recently.
murphy55d
11,542
I had a Hauppauge WinTV USB PVR and it worked pretty well, it was just overkill for what I wanted.
bluemax
7,182
I was going to suggest something similar... if you're not using it for TV, forget the TV tuner and concentrate on a VIDEO CAPTURE device, either USB2.0, firewire, or PCMCIA.
No suggestions for a quality product at this point, but it'll help focus your search.
kelvin1704
869
Sorry for making things unclear.
Basically, its like this:
We are going to have a LIVE input. The input that we have has DVD quality. Basically, we plan to control what is on our 400 inch rear projection screen with our COMPUTER. So we could do PICTURE and PICTURE with good quality from COMPUTER and VIDEO signal.
That is why I am searching for a Device that can ALLOW me to connect the LIVE VIDEO INPUT to the computer.
Extra Info:
The Canapus Video Capture, capture great video. But it only work with Adobe Premier which do not allow a Special Window let us make the "FAKE" picture in picture special effect. Because it only work in Adobe Premier. Unlike the one we had with Avermedia, u can move around the Window that has Video input. Thanks
bluemax
7,182
Well, most projector units will not only accept VGA signals but also S-video, RGB, and composite video too....
Can't you just plug this "source" straight into the projector?
Gibson486
18,378
If it is to play DVD's, then just get a normal usb turner i guess. I do not know how the cost is, but for $60, you can get an external video capture kit, at sam's club, that will let you feed the DVD player in live.
