Considering getting back into water cooling once AMD's Zen 8C/16T processors launch. I'm only looking to cool the CPU at the moment using a standard distilled water loop.
Questions:
1) Has anyone used or built an external rad box before? Reason: I'd like to have quick disconnects outside my case/in a PCI bracket allowing me to basically have a self-contained radiator/reservoir/pump box for easier maintenance.
2) For pumps, I am currently considering using an Eheim aquarium pump or similar as I've been less than impressed with hobby-grade pumps (I had a vario D5 die on me under light duty). Maybe a submersible unit like the Compact 600. Maybe two of them for redundancy. Suggestions?
3) What quick disconnect connectors to use? I see a lot of mixed reviews out there...
What parts I have lying around:
Swiftech MCR320-QP 3x120mm radiator
XSPC EX420 3x140mm radiator
(A lot) of Scythe Gentle Typhoon 120mm AP-14 fans
(A lot) of Swiftech Helix 140mm fans
Bunch of EK High-Flow fittings (G1/4 - 3/8" OD)
Various 3/8" ID 5/8" OD tubing
Silver kill coil
I suppose the cheapest solution would be to improvise using an old ATX case I've got lying around and turn that into the external watercooling box, but I wanted to see what other people have built/thought of. Thanks.
Questions:
Silver kill coil
