External HP USB CDRW C9635A $79.94 Plus Tax
ShatterGhost
37
I was just up at my local Target store in Saint Louis MO. and they had three HP CD-Writer CD4CE USB external writers model number C9635A in the clearance section for $79.94 marked down from $159.99. This is not the Boxy looking External CDRW that they make, this is the slick streamlined black and silver one. It fits great in my Zero laptop case along with my laptop.
Package contains:
* HP cd-writer cd4ce external USB CD-rewritable drive with 2 MB buffer
* One Blank CDR
* USB Cable
* Slim external power adapter
* Quick start placemat
* Support Guide
* Software
* CD creation software (will update when I find out what version)
* ArcSoft My Photocenter
* Musicmatch Jukebox
* ArcSoft PhotoStudio
*CD labeling software
This is my first post to the Hot deals forum so if this isn't such a hot deal be easy on me, but it seemed like one to me and it is the cheapest I have seen for this type of writer.
madalien
271
Not bad, around here in Wisconsin they are still listed at $110.00. Too much at that price.
unclebud
5,518
i bet it was the south county one.
those gone from here @ $135 :(
good luck and bump for the others though :)
Snyder81
460
My local target had one of these, but I don't know if it has been marked down to this price yet. Do any other retailers carry these? Best Buy, Circuit City? Are there any rebates available?
ShatterGhost
37
Cyberguy,
It was the one on Hampton, right across the street from Hampton Village. I only bought one they had two left. Make sure you have them scan it, mine had two clearance stickers on it, one marked from $159.99 to $135.00 then another sticker on the other side at $159.99 to $79.94. I had them scan it at the check out and it came up 79.94 without him looking at the tags. It doesn't hurt to take them to one of the scanners they have around the store just to check, but when I left at 8:30 PM on the 8th they still had two left and also one of the bigger nasty boxy looking ones. I hope this information helps. Take care.
