I just bought a Kanguru 80 gig firewire/USB 2.0 external HD. It's hot swapable so when I'm in windows and I plug it in it's there and I can use it. The problem is is that if I reboot with it attached the computer hangs at the ASUS logo before widows boots. I also cannot enter into BIOS with it running. My I have two internal drives and the OS boots off the F: drive rather than C: but I don't see how that would change anything. The Kanguru drive is H:... This symptom occurs when attached with either firewire or USB. Let me know if ya'll have any ideas.
Thanks,
crelm.
ASUS P4C800-E deluxe
P4 2.8E Prescott
512 OCZ dual DDR 400 mhz platinum
ELSA Gladiac 32 (I know)
Plaxtor 52x32x52
Pioneer 16x DVD
SB Live 5.1 Platinum
Trinitron 17"
Win XP Pro
Thanks,
crelm.
P4 2.8E Prescott
Plaxtor 52x32x52
Pioneer 16x DVD
Trinitron 17"
Win XP Pro
