I have a laptop (Presario 900Z) and I just got a 3-port firewire pcmcia card. Now I bought a external enclosure (ME-720F) from compgeeks and put my 80GB 7200rpm in it. I connect everything, run a benchmark in SiSoftware SANDRA and the drive index is only 10MB/s. I knew that the ME-720F is known to do 20MB/s average.
So I took the enclosure and tested it in a friend's desktop through firewire. He got the expected 20MB/s in SANDRA. So I thought it must be the PCMCIA card that's the prob.
Then I took the enclosure AND pcmcia card and connected them to another friend's Sony laptop. And he got the expected 20MB/s in SANDRA also. So the card is not the prob either.
So it's not the enclosure's problem, not the harddrive's problem, nor the PCMCIA card's problem. I'm baffled. I'm totally stuck.
BTW, I'm using WinXp so the drive/card are all auto detected and works all fine. I also have minimal background services running in WinXP so my laptop runs pretty fast. The PCMCIA card's chipset is VIA.
It's just that I get 10MB/s in SANDRA. I can't think of anything else that can be wrong. I tried switching around the cable in the ports. No difference. I mean, IEEE1394 is IEEE1394, it's a standard. But I'm getting exactly half the speed.
Thanks. Any help is appreciated.
