- Jul 18, 2007
- 10
- 0
- 0
Hi,
Im trying to build a External Drive for the first time with the following materials, but I cant get it to work...
Materials:
Seagate 500GB Barricuda
AMS Venus DS5 - Firewire/USB2
Basically I install the HDD and the external case shows up under the device manager but the HDD never shows up on "my computer" so I can't format it, etc.
I know the problem isn't the enclosure because I put a DVD drive in the enclosure and the DVD drive worked just fine.
I also tried the HDD in another enclosure and got the same result.
I have tried connecting both by USB and by firewire. And I have tried connecting to two different computers.
I did move the jumper pin so that its set on the first pins (closest to the IDE cable). Am I missing anything? This should be just straightforward plug and play right?
Does this mean I just have a bad hard drive??????
Help please
Materials:
Help please
