External hard drive problem
hans030390
My brother has a western digital 120gb external hard drive. When he plugs it in, it turns on and acts as if it's spinning. Then it will make a clicking noise and quickly sound like it's stopping and spinning again. It does this 5 times and then quicks spinning together.
The computer will recognize the hard drive, but you can't transfer any data with it.
Any help?
Sounds like the old "click of death." You can try downloading and running WDC's drive utility.
WDC
My computer makes the beepy noise (saying I plugged something in) when I plug it in...but it never shows up or is recognized.
It doesn't show up on the program either, so I can't do anything with it...
A spin-up followed by several clicks in a hard drive means it is trying to read data and had an error. It sends this message to the operating system that requested the data, and the OS tells it to try again. This sequence will proceed several times (usually 5) before the OS gives up and tells you it cannot retrieve the data you wanted.
Now, at the very beginning, you did not ask for data. It was just the OS trying to establish a connection to the HDD. So after 5 tries it gives up and does not TELL you it had a problem. It simply does not acknowledge the existence of the drive it can't talk to.
The problem could be the hardware side of the HDD, or it could be corrupted data (including data in the disk directory or FAT system). As corkyg says, download and try the WD testing utilities. If you're lucky it can find a fixable problem, and the whole disk will be OK again. Or, at least, a work-around that would allow you to recover most of the drive's data and lose only a little bit.
Faint hope clause: I have had this behavior occur simply due to a poor connection in one of the 40 (or 80) pins of the data cable to the HDD. It was fixed many times by unplugging and re-connecting a few times to clean the connector. It's free and worth a try - just don't be too rough about it!
