external hard drive enclosure need help
mlody
hello
I am looking for a good external hd enclosure that will fit 3.5? hd and has USB2.0 and firewire. Since I have a hd already I am looking to buy just an enclosure. Any recommendation? I have found some and they were ranging from about $100 to $150 to what I need. Paying $150 for just enclosure is kind of too much since I can have 120gb external hd, so I am looking at the lowest possible price.
Thanks for any info
here's one from svc that's only $80 link.
You can save a lot by sticking with only one of the two connectivity options. You can get this same drive with only usb2 or only firewire for just $50. You can also search ebay for "hdd enclosure" to fine even better deals.
