External hard drive dropping connection...
cycleman77
352
I leave my computer on for days at a time, and my external hard drive randomly drops its connection.
I never paid too much attention to it because I would just unplug it and then plug it back in.
But recently I have been burning DVD's and the source of the data is on the external drive. In short, I have a collection of DVD coasters starting. I am not happy with that.
Anyone have any ideas of the source of the problem?
The length of time my machine has been running does not seem to be a factor.
Notes: Running Windows XP Pro SP2, External hard drive is a Maxtor 200GB w/ firewire.
Thanks
corkyg
Elite Member | Peripherals
27,370
240
Are you using a separate ower brick for the Maxtor? Have you tried a different Firewire cable? Should be 6 pin to 6 pin.
cycleman77
352
The external enclosure I am using is an Argosy HD-360C. I am using a standard male-to-male 6pin cable.
Zepper
18,998
Is "Delayed Write" disabled? Should do that with all external drives.
.bh.
Zepper
18,998
Do you have ASPI layer software installed? It should be when using external drives, especially with Nero. You can use Nero's own or the Adaptec. The Adaptec comes with a utility to tell you if ASPI is installed and what version.
.bh.
