External DVD burner to Internal DVD burner
S Freud
I have an External DVD burner that I used to use for my laptop, I recently purchased a desktop and I was wondering if its possible to take the DVD burner out of the enclosure and put it into my desktop?
Thanks
Yes, I did that procedure from internal to exterior and vice-versa.
But depending on the model, unless its a 18X DVD burner, it wouldn't be an improvement or advantage to remove from its portable enclosure.
Very simple. disassemble the external enclosure, and you will find inside.... *drumroll*
A totally standard 5.25" internal DVD burner, complete with IDE and Molex connectors.
Pull it out, pin the jumper as necessary and connect her up. Brainless.
~MiSfit
