There is a way, but you have to drop two files into your home directory. Once you do that, you can apple+click the burn icon and it will burn the dvd using the writer of your choice.
I hear panasonic burners have good support ... check out the macnnn.com peripherals forum and they will hook you up with all the info. I personally have burner in an external enclosure that works...
