Extension cables of motherboard LED, Power Switch cables?
Mwing
I have changed my computer case, but the problem is the wires (power switch, powe LED, HD LED, reset switch) are too short to connect to the motherboard because the connectors are located on the bottum right of the motherboard, while the other ends connected to the top of the case. Is there any extension cables availible to purchased on the net? I have searched in many places but no success.
Thanks!
If you can't find extensions:
cut, split and strip wire carefully
slide on 2" shrink tubing sections
splice in 6" extension wires (continue polarity)
solder connections (twist tight if not soldering)
heat shrink tubing and your done.
As long as it's fairly close to the original gauge (thickness) of the existing wires then it should be fine. Try not to go thinner (higher gauge) however.
