extending USB 2.0 webcam, in-wall cabling
Kremlar
Looking to locate a HD webcam about 30' of cable away from a PC. Through a wall, mounted high for Skype use in a small conference room.
Since the cable needs to be in the wall for aesthetic reasons, I need a suitably speced cable.
Monoprice sells a 33' USB extension which gets good reviews, but they say it is not in-wall rated.
I'm looking at Cat5/Cat6 USB extension kits, but it's big money for something that supports USB 2.0 transfer rates (over $300).
Any other options I might be missing?
I stated I already looked into those, but the catch is USB 2.0 support. Only one i found that supports USB 2.0 is over $300. Since it's an HD webcam, I think USB 2.0 speeds will be required.
