- Aug 26, 2011
- 6
- 0
- 0
Hello,
I hope this is the right place. First time posting, but it seems like some people out there may have some ideas for me.
I need some help. I'm just a hobbyist and I'm trying to setup some cheap wireless PTZ IP Cams. Setup is not the issue. They work fine as delivered. I'm trying to do something a little more unique. I want to mount them were there is no electrical outlet for 100 feet. Essentially around the roof line of my 2 story house.
So far I've tried cat 5 and 18 gauge speaker wire with no luck. So before I get into all the details, let me give you some specs.
The camera came with a 5VDC 1.5 amp power supply. The draw is less than 6 watts. I metered the power supply and it puts out between 4.9 and 5.2 volts. I was not able to test the volts with a draw, or measure the amps.
Test 1
So the first thing I tried was to get some injectors and try POE with Cat5. I get an image, but it is a still frame, and no servo control. With this I concluded that at 5 volts, the voltage drop over cat 5 was too much at 50 or 100 feet.
Test 2
My second thought was to get a 5 volt 3 amp 15 Watt transformer, connect it to a distribution block, and wire in a barrel connector. First I tested with a 10 foot 18 gauge wire. It worked fine. So the transformer was good. When I metered the transformer, it put out 4.88 volts, and after a draw, 4.6 volts. I then added 50 feet of wire. The result was the same as the cat 5. Just a still image and no servo control. When metered at the source, it was 4.88VDC. At the end of the 50 foot wire it was 4.88 VDC. After I put a load on it (Connected the camera), VDC dropped to 4.25.
Test 3
So again, I figured I needed more power. Since I have about 100 DC adapters laying around, I found 2 to test. One was 7.5 volts at 1 amp, and the other was 6 volts at 3 amps. Both metered without a load, were putting out over 11 volts. But neither would work. The 7.5 VDC adapter dropped to around 5.8 to 6.5 VDC with a load. But nothing, not even an image. I removed the 50 foot wire and connected directly to the adapter. Nothing. I tried the 6 VDC 3 amp next. Similar results, although when connecting directly to the adapter (without the 50 wire) this adapter dropped to 4.2 VDC with only the original 3 foot wire attached.
So now I'm confused. I'm not sure what to do next. My thought was to use an old computer power supply and send 12 VDC over the wire, and attach a 5VDC voltage regulator right next to the camera. But test 3 suggests that might not work either.
Can anyone tell me what I'm doing wrong. I thought DC was DC, and it would be simple. Obviously not. How ideas on how to make this happen without spending a fortune. A true POE PTZ camera is way too much for my simple application.
Any assistance would be greatly appreciated.
Thanks.
Crawler
Test 1
Test 2
Test 3
Thanks.
Crawler
