i apologize if my search capability is not as advanced as some of you. I have searched all over Anandtech and Google to try and find an answer that I can understand and implement. I appreciate all of your help.
Here is the situation. I have just changed my room and the new room doesn't get wireless in one corner...of course, the corner that my computer desk is. In some parts of the room, I do get a signal, but is "Low".
Here is how my router is setup:
<-----> means ethernet cable connection
Cable Modem(in garage) <---100ft cable--->Router(linksys WRT54GC)<--100ft cable--->Hub(in garage)<----->PC(in garage)
2 laptops connected via Wireless
I have a HighGain Antenna on the Router and that doesn't help my situation. There is no way i can get a cable to this location and I can't move my router either.
I need something that I can put without a Network Cable going in...so basically wirelessly.
Would a Bridge, Repeater or Access Point help in my case??? If so, what is the best option without downgrading on speed yet, increasing the range?
Thanx again.
Thanx again.
