Pulsar
I've got a Buffalo router in the basement right now. I'd like to move the antenna up to the ground floor so we get decent reception outside the house as well.
What type of cable can you use to connect the router to the antenna? Is it standard 75ohm coax, similar to the stuff you'd use between your TV and your TV Antenna? Does it use the same connectors?
I must be googling for the wrong terms because I can't find it.
