Hello,
A couple weeks ago I bought another 256mb ram for my computer. I decided to reinstall xp so i could reset up my partitions for swap drives and such. So after I do this, everything is fine, and i install sp1a. After this reboot windows won't load. it stays at the splash screen.
So i go in safe mode and remove sp1a. Then it's fine. Then I install my video drivers. A reboot later, the same problem. So i put the xp cd in and when it loads all of the install stuff, I ask it to repair the installation, so it recopies the files and then it loads fine.
Now, when I restart the computer, it once again won't load. Not even into safe mode. Every once in awhile the bios gives me a "primary drive fails" when I restart, so I figure maybe my old 8gb swap drive is dying, so I take it out and reinstall windows. Everything seems to be OK, I get my video drivers installed and sp1a installed, but then I install Opera and zip drivers, and once again, I can't load windows. At least this time I can get in safe mode.
Does anyone have any ideas what could be causing this? Is my aging computer just dying (which I highly doubt)? Did i buy some shoddy ram?
here are my specs
P3 500 slot 1
Asus p3b-f
512mb pc100
matrox g400
100gb WD special ed. ata/100 on a separate ata/133 controller card
Any help would be greatly appreciated.
-silversum.
here are my specs
P3 500 slot 1
Asus p3b-f
512mb pc100
matrox g400
-silversum.
