I have a rather large house and I am unable to connect wirelessly in my back yard. I don't want to spend the money to get a repeater. Instead, I'd like to extend the range of my network using two access points.
One way to to configure the access points to use WDS. I connected one AP to my wired network, and the other remotely, positioned close to the backyard (but still inside the house). I got this working. The problem with WDS is that the bandwidth of the AP are halved, and I would like to avoid this if possible.
Another idea I was exploring is using one of the AP to bridge the two networks. I set the AP connected to the wired network in wireless client mode and to operated as a bridge. The actual wireless AP is position remotely and not physically attached to anything. In this configuration, I am able to access my internal wired network wirelessly. However, I cannot access the internet from my router. I run Kerio's WinRoute to do NAT and DHCP. The remote machine is able to access my network (included being assigned an IP by my DHCP server) but unable to connect to the internet (DNS works, but nothing else).
For testing purposes, I tried switching the roles of the two wireless APs (so wired network is connected to the actual wireless AP). Then connecting one computer to the bridged AP. Everything works in this configuration. Of course this is not a real solution (unless I attached a third AP to the briged AP). Could WinRoute be the cause of the problem by preventing access becuase of it own security policies (I don't see anything in the logs)?
Another question I have is whether this briged configuration will actually improve performance. I'm thinking that in bridged mode, latency will increase since the AP will have to foward packets to the bridged AP, but bandwidth should not be significantly reduced.
