I have a system with a RV082 Cisco router (8-port) hosting 7 stations all well within 50' and the 8th port uplinking to a LinkSys 16-port unmanaged switch.
All works fine on the systems hooked to the switch with the exception of two systems that are connected as follows: CAT6 from the switch, about 150+' to a linksys route with the DHCP server turned off and that serves as a switch to the two slow stations that are within 15 feet of the linksys router.
If I have both of the systems on, it is so slow it feels like Dial-Up. If I disconnect either, then it is noticably faster, but still no where near what the other 4 stations out of this switch or the seven stations out of the Cisco router are doing.
I really need to have both of these stations running at the same time with a decent throughput . . . any suggestions?
