ext drive for use between a mac and pc
SAWYER
16,742
42
I have a 1.5 tb drive, what would be my best option to use it on both? One partition for mac and one for pc? What file type should I set up both as if I do it that way?
Eug
24,184
1,825
If just one filesystem, FAT32 works for both, but has no large file support.
Macs already have NTFS read support, but no write support. If you install Apple's Bootcamp HFS+ driver on the PC, you'll get HFS+ read support, but not write support.
Otherwise you can use a 3rd party NTFS driver for the Mac, or a 3rd party HFS+ driver for the PC, for full read-write support.
Or you can use exFAT.
dagamer34
2,591
Keep in mind that exFAT wasn't really designed for hard drives. If you'll be doing a lot if file sharing, I'd actually get a cheap NAS.
Kaido
Feb 14, 2004
52,461
7,688
Yup like Eug said, those are your choices. With FAT32, you're stuck at max 4GB per file. With NTFS, you'd need a driver for Mac - $20 from Paragon:
http://www.paragon-software.com/home/ntfs-mac/
If you'd rather make a Mac-formatted drive, you can get MacDrive for Windows for $50:
http://www.mediafour.com/products/macdrive
I'd recommend going with the Mac plugin - not only is it cheaper (twenty bucks), but NTFS is more widely supported, since the majority of computers on the planet are Windows-based, so you can pretty much take it anywhere and use it if you need to.
ViRGE
Elite Member, Moderator Emeritus
167
Can you explain how functionally that'd be a disadvantage?
It's really not. There's no file system journaling (among other things), but it's a good FS for quick mounting and dismounting of external drives, which is what you would want.
