explorer died.. help!!
everytime i open a folder ... i get an explorer fault and cant open the window
i have reinstalled xp home and downloaded explorer 6.1 again... still no fix
im running outta options here
can you provide us with a screen shot of the error?
are you able to browse the folders using a command prompt?
when you reinstalled, did you just do a repair or did you reformat the drive and start fresh?
What do you mean by explorer 6.1? Internet Explorer 6.1? do you mean IE 6 sp1?
try it with just a new install of XP - cos it might be the Service Pack causing problems
Then try the Service Pack and see if the problem quips up...
i believe he just did a quick reinstall or repair...a reformat would almost definitely get rid of this problem no?....
what error is it exactly? whenever you post a problem here, you have to give all the details....because an explorer fault error can mean anything really...
if anything, try searching the knowledge base of support.microsoft.com.....the site bailed me out numerous times.....well, hope everything turns out ok 🙂
no i didnt format... i dont have the full version of xp home
just the recovery disk
Windows Explorer has encountered a problem and needs to close. We are sorry for the inconvenience
AppName: explorer.exe AppVer: 6.0.2800.1106 ModName: xtupdate.dll
ModVer: 1.0.0.1 Offset: 00001cd5
and yes.. i installed the newest version of internet explorer.. i was gonna try an earlier version but evidently u cant downgrade...
no i can not open folders w/ command prompt
it seems that anything that is associated with windows explorer i cant access
ie.... folders, control pannel, etc..
the weirdest thing is that my desktop programs that arent in folders .. i can access easily
and yes i have been searching microsoft's support section.. cant find anything
bah.. i guess my only alternative is to buy a copy of xp pro full version .. format and lose 60 gig of stuff
what error do you get when using a command prompt?
As far as I know, you can use a recovery disk to format and instal windows. My roomate was able to do a fresh instal using the recovery disk from his Compaq, but this may vary between manufacturers.
Can you repartition the drive so that your current "C:" partition is smaller and make a new partition to install XP onto? or make a new partition to copy everthing you want to save with Xcopy?
And with XP, you should be able to do a System Restore from the point right before you installed the update. Might lose SOME files, but some is better than all. Should be able to run it by booting into safe mode. -TAL
