- Jan 30, 2009
- 700
- 0
- 0
First off, let's keep any fanboism or apple bashing out ... that's what off topic is for
Second, I'm not sure if this is 'highly technical' but I'm hoping the answer would be ...
my background is MS in EE but it's mostly on device physics so I'm not familiar with all this RF stuff ... but curious as to what the problem is.
First off, very basic, how does the antenna work? Second, how does the antenna gain depend on the signal strength, and lastly can someone explain why there is a problem?
I understand that if you somehow bridge the two sides by holding it in your left hand, then you'll lose some signal strength ... is it because you're body is shorting part of the signal to ground by doing that?
TIA!
TIA!
