Explanation difference between managed and unmanaged switch?
paruhd0x
3,100
Going to a LAN party in a month or so and the network is always slow due to people using like 4 hubs connected to each other... so I'm lookin on ebay to get a good 24 port switch and I don't know the difference between a managed and unmanaged switch. Not asking for someone to write out a paper... a link that explains it I would be most greatful for. Thanks.
ktwebb
2,488
Simple answer is managed switches allow you to interact with it using various tools. Connect via IP and a browser or telnet etc.., or you can use a serial or proprietary connection. SNMP traps, filtering, and so on. Unmanaged are dumb network devices. They have a job and they do it. Managed switches give you some flexibility and it really depends on the software as to what features your able to use. Need a processor and additional software so they will be more expensive. I imagine there will be others with more articulate responses but I wonder if there are any websites that disect this. It's just not that dificult a thing to figure out. Managed, Unmanaged. The name alone is implication enough to understand the difference.
JackMDS
29,563
432
1. You do not need a Managed Switch for LAN party.
2. Managed Switch is much more expensive than regular Switch.
3. Most modern Managed switches has a GUI interface that might provide you with:
- Real-time port utilization, Status, and error information.
- Port-utilization statistics
- Packets transmitted and received.
- Can capture a specific port's performance.
- Would indicate an NIC that causes excessive errors.
- Controlled Bandwidth, and distribution.
:sun:
dchakrab
493
and 4. A router is usually cheaper than a managed switch, gives you way more options (or more useful options anyway) and will do more for your network. And you can tell the router to just work as a dumb switch for simplicity, when you need it.
Managed switches are usually commercial or industrial grade devices, not consumer networking produtcs.
AFB
10,718
Originally posted by: ktwebb
Router's aren't really a part of this thread. Apples and oranges.
Exactly, you just need a mid-range 24 port unmanaged switch.
Thoreau
1,441
i reccomend dell for this area. I had picked up a 24 port 10/100 linksys switch a while back for $130, and while it's an awesome switch, you can get the same thing from dell but with dual gigE uplink ports, soo you'll have some room for future expansion.
Caveman2001
582
And I think the 24 port at Dell is cheaper than the Linksys right now. I checked and the 24 port 10/100 was like $84
