- May 23, 2003
- 11
- 0
- 0
Thanks in advance for ANY & ALL help, truly.
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
? Maya 3D modeling & rendering (incl. crowd simulation, CPU Intensive?)
? Extensive Photoshop work (multi open files from 10-60MB)
? FLStudio Music/Sound Design composing/rendering
? Video Compositing/Editing/Green Screen
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
$1300-1500
3. What country YOU will be buying YOUR parts from
USA
4. IF YOU have a brand preference.
? Intel Core 2 ___ [Duo, Quad]
? NVIDIA
5. NEW Spec?d System - AND - MY Current parts are mentioned together / per device (where applicable)
LOOKING TO PURCHASE RIGHT AWAY ? tonight if possible:
CPU: Intel Core 2 Duo E8500 3.16GHz LGA 775 65W Processor
Item #: N82E16819115036
Was considering your opinions on if I should try and go for the Quad setup, due to my needs in question #1 ? Intel Core 2 Quad Q9300 Yorkfield 2.5GHz 6MB L2 Cache LGA 775 95W Quad-Core Processor
HEATSINK&FAN: ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler
Item #:N82E16835186134
MOBO: ASUS RAMPAGE FORMULA ATX Intel Motherboard
Item #:N82E16813131284
RAM: CORSAIR DOMINATOR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Item #:N82E16820145197 NOTE: I'll start with 4GB, and get another 4GB within 60-days
POWER SUPPLY: CORSAIR CMPSU-750TX 750W Power Supply
Item #:N82E16817139006
CASE: Antec Nine Hundred Black Computer Case With Side Panel Window
Item #:N82E16811129021 FYI on a case: I could care less about blinking LCD lights ? I need cooling capability! ?
HARDDRIVE: Western Digital Raptor X 150GB 3.5" SATA 1.5Gb/s Hard Drive
Item #:N82E16822136011
BURNER/ROM: I?LL USE MY current HP DVD burner w/ Lightscribe for now
DVDRW/CDRW: HP dvd840
VIDEO: MSI GeForce 8800 GT NX8800GT 512M OC PCI Express 2.0 x16 Video Card
Core clock 660MHz, Stream Processors 112, Memory Clock 1900MHz, 256-bit GDDR3
Item #: N82E16814127329
SOUND: I?LL USE MY current Creative Sound Blaster card for now PCI (7.1) Channels
MONTIOR: I?ll get new monitors shortly after the main purchase. I was REALLY blown away that out of 1300 feedback results, 77% had 5-stars, and 14% gave it 4-stars (Newegg). I never considered this vendor?thoughts?
Acer AL2216Wbd Black 22" 5ms Widescreen LCD Monitor with HDCP support 300 cd/m2 700:1 - Retail
Customer Choice Award - 4x Winner of Customer Choice Award - LCD Monitors
OS: Windows XP Pro 64bit
6. IF YOU have searched and/or read similar threads.
Did a bit of research on different HW review sites, and spent quite a while on NEWEGG feedbacks
7. IF YOU plan on overclocking or run the system at default speeds.
I?m not an Overclocking HW builder, I?ll tackle that AND how to setup a cooling system at some point
8. WHEN do you plan to build it?
Looking to purchase parts tonight, if it works out. I just like to have others do a thorough review.
Thanks for ANY & ALL help, truly.
$1300-1500
USA
? NVIDIA
- o Geforce is way better for Real-time game/sim - [I?m looking at the new PCI Express 2.0]
o Quadro is better for Eng-Computing
o I?ll probably go with the Geforce, as it?s about 1/8 cost?
- o Seriously considering the COOLER MASTER COSMOS 1000 RC-1000-KSN1-GP Black ATX Full Tower Computer Case
- o Question: I?m not a Raid expert, however, does anyone think I need to get more into that - and how expensive for a decent setup (I don?t lose data now, but I would like to know your opinion)
- NOTE: I CURRENTLY HAVE THE FOLLOWING HARDDRIVES TO USE ?FOR NOW?:
Internal: 2 x Barracuda 80GB 7200 RPM Serial ATA
External: Western Digital 500GB Ext USB, and a SimpleTech 200GB Ext USB
