Exchange 2000 guru please help
err
I would like to block a message from the whole domain in Exchange 2000, say for *@yahoo.com
How do I do that ?
Thanks !
err
open properties of the smtp server click the access tab, click connection
select "all except the list below" then enter the domains you want to block in the format:
*.domain.com
thats straight from MS hope it helps
DnetMHZ
<edit>Knowledge Base Article ID: Q251457 if you wanted to read it</edit>
Thanks for the info man. I've actually tried the SMTP connection settings before and it did not work because I only did
yahoo.com
or
*@yahoo.com
The right one should be *.yahoo.com
and you need to RESTART SMTP in order for it to take effect.
Thanks for bringing up the KB.
eRr
