artemicion
The fan on my vid card is making an annoying, but not too loud, grinding noise ever since I started it up today. Kinda like the noise you get when you stick a baseball card in the spokes of your bicycle.
So I opened up the case, I first discovered that the vid card wasn't seated properly (yet it was still working), so I pushed it back in all the way, but that didn't fix it.
Then I took it out, and discovered a HUGE amount of dust that built up all over the fan and heatsink, which I gave a decent, but not completely thorough, cleaning.
I stuck it back in, and at first, the noise was gone, but I came back later, and now it's back, though I think it my be not quite as loud as it was before.
What should I do?
(GeForce TI4200)
What should I do?
(GeForce TI4200)
