- Nov 24, 2005
- 564
- 0
- 0
Ok fellas...I come to you asking for bigtime help here.
My computer consists of the following:
CM Stacker 830 Tower
ABIT IP35 Pro mobo
Q6600 CPU
Tuniq Tower
8 GB RAM
3 HDD's
8800GT
8600GT.
W/ the stacker, all fans are 120MM Yate Loon D12SM-12 - Medium Speed ones, and I have 1 intake fan in front of the HDD bay, 2 exhaust fans at the back of the case, 1 exhaust fan at the top of the case, 1 fan inside the Tuniq blowing directly towards the exhaust fans and 3 intake fans just inside the access door on the side of the case...
Now, I am also running Vista x64 Ultimate.
I've had my computer off all day and just fired it up. As soon as I boot up, I start up SpeedFan as well (4.38), and immediately, it's showing my GPU's at 58 degrees Celsius and my the 6th temp down (what is this?) is reading a balmy 66 degrees Celsius.
Then, after running for about 10 minutes, that climbs up to 67 and 64 degrees C, respectively. Now, it's not THAT hot in my office and this is with my computer being off just about all day (at least it's been off for about 4+ hours).
So my question is this: Is SpeedFan giving me bad info (is it not working w/ Vista 64?) or is it really possible to be generating that much heat, nearly instantly? I have my side panel off and it's just not anywhere near those temps in my rig right now.
Please help. We have ordered higher CFM fans to replace all the fans, but something just seems off, in the meantime.
I should lastly point out that my gf's computer in her office is also saying similar numbers (with a nearly identical setup) w/ SpeedFan, and no, neither system is overclocked.
Help?
ABIT IP35 Pro mobo
Q6600 CPU
Tuniq Tower
8 GB RAM
3 HDD's
8800GT
8600GT.
Help?
