- Apr 17, 2004
- 17,555
- 1
- 0
OK here's the deal: I have a formula which references a cell. I want to use a value in another cell which I can change to increment which cell I'm referencing.
Here's an example:
Value in cell H1: 0
Cell referenced: D3+H1 = D3+0 = D3
Value in cell H1: 1
Cell referenced: D3+H1 = D3+1 = D4
Value in cell H1: 2
Cell referenced: D3+H1 = D3+2 = D5
All of the values I need to reference are in the same column, so I need to be able to increment down the column. I can't figure out how to increment a column location by an integer, how do you do this??
Thanks all!
Here's an example:
Value in cell H1: 0
Value in cell H1: 1
Value in cell H1: 2
Thanks all!
