Excel Question (Macro, Vlookup, other method?): Same name highlighting
max347
Hi guys, I have a column of names in A column, and a column of names in B column. I need to highlight (or put into a third column) the duplicates. The catch- one column is in "first last" format and the other is in "last, first" format.
Ideas?
Thanks!
Assuming clean formatting of the names, can you break up one of the columns using Text-to-Column, then recombine them to match the other column's format (using Concatenate or simply using "&" functions)?
Once you have the 2 columns matching in format, you can use the "if" function in column C to highlight any matching rows, e.g. IF(A2=B2,"DUPLICATE","").
Unfortunately the one column is severely non-formatted. ie, different spacing, some have jr, sr, ms, etc.
I will check out this method and see what I can come up with however.
I was checking out the fuzzy sort thing by microsoft however it just seems like a way to do database style tie-togethers...not really a sort.
Yeah so this is what I was trying to use, but unfortunately it won't work with "similar" names, just exact matches-
Code:
Sub ColorDuplicates()
'Color duplicate items between columns A and B
    For i = 1 To Range("B65536").End(xlUp).Row
         If Application.WorksheetFunction.CountIf(Range("A:A"), Range("B" & i)) = 1 Then
            With Range("B" & i).Font
                .ColorIndex = 3
                .Bold = True
            End With
         End If
    Next i
    For i = 1 To Range("A65536").End(xlUp).Row
         If Application.WorksheetFunction.CountIf(Range("B:B"), Range("A" & i)) = 1 Then
            With Range("A" & i).Font
                .ColorIndex = 3
                .Bold = True
            End With
         End If
    Next i
End Sub
