Excel Help
austin316
3,572
Ok, I'm getting extremely frustated and I think it is due to the fact that I don't know the syntax that is needed. Here is what I would like to do.
For the following function
=HYPERLINK("[Vouchers v020309 master backup.xls]'012809'!E2", "link")
I want to change the hard coding of the file name to something that is dynamic. To do this, I used the filename function and now in cell A1, it displays the text "Vouchers v020309 master backup.xls" (without the quotes of course).
However, when I try the following function, I get errors:
=HYPERLINK("[A1]'012809'!E2", "link")
Obvi, my problem is syntactical, but I can't pinpoint the problem. I've tried every combination of & signs and quotes that I can think of and it still won't work. Any help?
Ken g6
Moderator
Dec 11, 1999
16,835
4,815
75
If I'm reading this right, you need to think in terms of concatenating strings:
=HYPERLINK("["&A1&"]'012809'!E2", "link")
austin316
3,572
I get an error message "Can not open the file" with that code.
Ken g6
Moderator
Dec 11, 1999
16,835
4,815
75
OK, in another cell, try:
="["&A1&"]'012809'!E2"
And compare it to your original string.
You might also try:
=HYPERLINK("["&trim(A1)&"]'012809'!E2", "link")
austin316
3,572
You might also try:
got it! thanks! I didn't need to include the [ and ] brackets.
