Excel Help
FallenHero
Is there anyway to make it so that a cell in excel turns red one year after a date is entered into it?
Example would be you took a driving test on 11/13/14 and that date is entered into excel
On 11/13/15, the cell automatically changes to red to indicate that the driving test needs to be re-done and makes it real easy to spot those that need to take the test again?
Also, would there be able to be a warning given with say 30 days out, the cell turns yellow?
I dont mind using multiple sheets if needed, but I would some pointers on getting the fuctions to call the specific cell from a different sheet if needed.
Sorry if this seems basic to some of you, it's been years since I've had to do anything with excel at all.
yes it's possible. Do I know how to do it without copius amounts of googling? nope, but I've definitely seen it done.
Yes - you'll need to use conditional formatting for this (there may be another way, but this is the only way I know of). I believe you may have to create your own rule since you want such a big range (one year). I'm sure throwing something into google for conditional formatting with dates will get you what you're looking for
cool, I'll start there. My google-fu is weak since I didn't even know where to start. If anyone has any specific examples or the exact formula, please post it. 😛
Yeah conditional formatting works for this. I usually jump to VBA functions for these sorts of things, but that is overkill in this case.
