Excel Help..
FlasHBurN
I am trying to make a formula that changes the color of a cell, depending on how it compares to another...
For example I have a cell (A2), I want to compare its value to another cell (B2). If B2 is greater than A2, I want to change the color of A2's cell.
I already know how to change the color of a cell based on its comparison to a specific number, but I cannot figure out how to change it based on the value of another cell.
Conditional formatting is your friend
you'll need to use an if statement
pm me if you need specifics
ok, specifics...
in cell A2, go to format-conditional formatting
first box should say "cell value is", 2nd box should say "is greater than", third box should say "=$b$2
click on the format box, choose the 'patterns' tab, and select your color - you should be all set
you may also want to put in some data validation conditions to make sure the values in column A are only numbers too
