Need a little help in Excel concerning IF, THEN statements...
Suppose I have two columns, Column A and Column B; both were formed by calculations (in it, they contain formulas to achieve what's in the cell right now).
So lets say that in Column A, I have a calculation; it can be any number. For Column B, I want to display a certain number that is directly from Column A (for instance, if Column A shows any number from "0" to "4", then I want Column B to be a "0". This is of course, after the original calculations have been made, so in a sense, it's like Excel would make a calculation, then check the other column, and then go through with the next formula.
Going further, if Column A displayed a number from "5 to 9", then Column B should automatically show "1".
REMEMBER, both columns have already been formed by a previous calculation, I just simply want to add a "layer" upon each. I know you would use the IF formula, but I've tried nearly everything, and thus, need to take my problems to ATOT...
Thanks!
Thanks!
