Excel Help/Question
yes and its relatively easy.
see kranky's link.
i like to use lists/drop downs in combination with database functions. (e.g., use drop downs to let an end user define search parameters for a report)
after you finish filling in all fields like the items below......
name address phone sex height weight
____ ______ _____ ___ _____ ______
Next you will need to select all item's, hit the box between A and I or edit select all
go to data at the top and select filter then auto filter. Now you will see each column
will have a drop down arrow allowing you to choose.......
Hope that this is what you were looking for.
