If you are an Excel gawd, I could use a little help.
I am now tasked with writing some reports for some managers in another department.
The program that creates the data is Calyx's Point. This is a mortgage company processing software.
I create the data file from two sources and merge them together in one sheet in Excel. That part is easy.
Now every day I need to about ten different sorts, column and row deletes, sub totals, page breaks and associated things like that.
Can I automate these functions or write macros to do this automatically ?
Any help you can provide would be apreciated, thanks.
