exact procedure for fdisk
Eratosthenes
43
I'm going to do the initial setup of the machine I'm building in a few days.
I'm planning of having three partitions, one for windows, data, then programs. I know there is a /f or /s switch I need to put in when I'm (later) formating C (the drive windows will be on) but do I need to make all the other drives bootable as well? What is the exact command I should use to do this? I'm sort of looking for "type in this line for three different times for the partition, this line for format..."
Also, refering to the portion of text from tweak3d.net below, after I create my partitions do I need to run fdisk two more times to format the other partitions? At that point will I still be running fdisk off of the floppy? Again I just sort of wondering about the procedure. Thanks a million.
Era
(from tweak3d.net)
Before you format your hard disk, you need to partition it. And unless you own a copy of partition magic or another such program, you are stuck with old, archaic Fdisk. At the A: prompt, type in Fdisk to go into the program. Create a primary partition (your C drive) using fdisk and then restart the computer. Afterwards, you will once again need to reboot. Once you have rebooted the computer, type format C: /s (the /s makes the drive bootable) at the A: prompt and go do something else for about half an hour while it formats. When it is done, we recommend copying the Windows "cab" files (located in the \Win98 directory on the CD) onto the hard drive. This will make the installation faster.
PS I also heard somthing about making a partition for the swap file since it improves performance and you can defrag it. How is that done and what's the story?
Rig:
550MHz Slot A Athlon
Voodoo3 3500
13 Gig HD
128 SDRAM
10X DVD
SBlaster Live!
19 inch Q95
and uh...
2 firewire ports
So there!
