I'm looking to replace some 1 TB disks with 1 TB SSDs. The disks in question are going to go in RAID1's, so they need to be the same size or bigger than the hard drives I'm currently using. (I'd like to remove one side of the RAID, rebuild to a SSD, and repeat for the other drive) I can't find the exact sizes in bytes of either of these drives.
I used msinfo32, components > storage > disks to find the size of the 1 TB drives we have now. They're Western Digital RE3 1 TB's, so 1,000,202,273,280 bytes. If you have one of these drives, can you please run msinfo32 or similar to verify the exact size in bytes of the drives?
