EX58 Extreme overheating
McCartney
388
Hi guys,
So the the Ex58 Extreme has a lot of LED lights on the motherboard to help you diagnose why your computer is on the fritz. Mine is completely fine, however I can't run my ram at rated speeds anymore. It seems that my motherboard has been slowly denaturing in its quality.
WHat happened was about 3 weeks ago I purchased some DOminator GT 8-8-8-24 6GB memory at 2000 Mhz. It ran great at 1.65 and no overclock on the CPU, until recently.
I would like to document that I couldn't run my Old Dominator 8-8-8-24 1866 MHz 2x2GB kit on this board at 1.8v even if I had tweaked the other settings accordingly. (Just giving a bit of history) but I kind of expected this as the "voltage safety" was 1.65V and so all we see is kits of this voltage or less.
Yesterday I got greedy. I haven't overclocked my i7 965 yet, with this memory and having my CPUs and GPUs under water you ought to think I've tried. Nope... I haven't.
After playing wow and getting annoying ass BSODs that are very new (still the same settinsg that worked fine for weeks prior) I was like "whatever, time to overclock this bitch if I have to go in bios".
So making sure all my other temps were safe I just dicked around and I saw that I had 4.0ghz at 1.45v on my i7 working great at an QPI/VTT voltage of 1.515... No big deal I thought, right?
Well the diagnostic LEDs went red indicating the MCP was "Too hot" (above 69 degrees) and it shut down. I just have that heatpipe apparatus attached to my motherboard and it's not watercooled (I didn't really think it'd need to be since i could run my memory at 2000 MHz 8-8-8-24 fine on no cpu overclock) and I thought that'd be enough. Lots of shutdowns ensued and tons of boot loops (prior to posting, indicating instability on previous settings, but this one worked well I could boot in and do stuff etc).
I was so wrong, so now I cannot even run my memory at 2000 Mhz with everything else on stock settings. If I try to up my memory to the rated speed and keep everythign else the same the MCP hits 70 degrees so fast that I can't even get in windows. Everything else works fine at 1333 MHz. I'm pretty sure my board is on the fritz though.
Thoughts?
EDIT:
So to sum this up:
I was running all stock speeds for my setup. I had the volts on auto and I had XMP enabled for my memory. I got a BSOD, and I went into bios and overclocked. I had the settings 1.45v CPU and a 1.515V QPI/VTT. It posted and ran ok, the board got hot and shut down.
I tried going BACK to stock settings (Exception of ram, running at 1.65V and 2000 MHz and I'm getting a shutdown with red lights).
lopri
13,310
687
I am not sure what you're trying to say.. You mean, you didn't know X58 was running so hot?
homercles337
6,340
Are you sure about the LEDs? I have the UD4P and there are no "temp" LEDs, just "phase." They give you an idea how OCed the memory, cpu, nb, etc, are. Are you disabling all the "auto" functionality with OCing? That is, are you messing with voltages manually? To be honest, i have found the LEDs to be useless.
McCartney
388
homercles337, it's hitting 69 degrees and when ti does the LED light by my NB goes red.
After that it shuts down. Like I don't know why running the memory now has caused such problems.
I'm leaving all the settings on AUTO except for the RAM which is running the XMP speed. The bothersome part is when the ram is clocked at the rated speed the board just over heats.
Any suggestions?
God Mode
2,903
You're not watercooling the northbridge or running it with a fan and wondering why its overheating?
