- Jul 6, 2010
- 2,270
- 1
- 0
Hi Everyone,
I need your adivce... recently I returned my PNY GTX 470 and bought a EVGA SuperClocked GTX 470 and I downloaded the EVGA Precision tool to monitor the GPU statistics.
I leave everything factory (superclocked factory setting is at 625MHz and 1250MHz) and the fan is set on auto which is at 40% during idle.
I turn on the EVGA Precision while I game and I notice some issues.
I was playing the new Medal of Honor with my monitors max resolutions at 1600x1050 59Mhz with all graphics setting on highest settings.
1. As the heat increases the fan does not speed up?!
2. Every 15 minutes I would get a freeze or lag - don't know if its the game server, the GPU, or the EVGA Precision Tool causing it.
3. I was getting kicked out of multi play games - I first thought it was because I was owning everyone on the servers and that an admin banned me because they thought I was hacking - then the last game I played I was completely auto existed the MOH game and I look at the EVGA Precision Tool GUI and saw that the GTX 470 was at 100+ degrees Celsius and the fan was still auto on 40%???!!!! The fan speed did not even go up to cool down the card!
I didn't have this issue when I had the PNY GTX 470 and I was able to game fine and had no heat issues.
Would the fan auto speed up to cool down the card if I don't turn on the EVGA Precision Tool? Or should I manually set the GPU fan at a speed to keep the GPU card cool enough were I don't get auto kicked out of games?
I thought the fan auto speeds up when heat on the GPU goes up?
I notice when I do manually set the fan it gets louders after 60% or higher speeds.
The fan on my previous PNY GTX 470 was pretty quite the whole time when I game.
I appreciate any advice or recommendation...:biggrin:
