EVGA NF4 SLi not compatible with P180
LiquidImpulse
2,062
after hooking everything up and leaving the jumpers and power led connections last, i learn that all the p180's connections do not coincide with the manuals "how to do"specification. It tells me to connect a 2 pin hdd power led cable to the 2 pin socket which it belongs to, but the supplied connections supplied by Antec's P180 have 3 holes in which 3 pins are suppose to be place
I'm all confused and this is happening to everything from the optical drive led,floppy,etc. please HELLPPP!!!
spacelord
2,127
I hooked my eVGA NF4 SLI board up a couple weeks ago and yeah, the connectors were a bit funny and the manual sucks ass. Search the forums at eVGA.com (under Community) I recall that I got it to work by doing alot of assuming and eliminating possibilities where the connectors could go. Are there 3 wires in the Antec wire? or is it just a 3 hole socket with 2 wires?
I can look at my MB tommorow, but I really need the sleep right now.
LiquidImpulse
2,062
also having problems with the 9 pin audio on the EVGA and the supplied cables from the p180. aud_fpout_L, aud_ret_L, aud_fpout_r, aud_ret_r connections dont match.
SophalotJack
Banned
Jan 6, 2006
1,252
I have the same mobo case setup, LiquidImpulse.
You don't have to use those numerous audio connectors at all... the P180 has them for old school hardware.
Use the all-in-one audio connector from the p180. It is compatible with the eVGA sound. I used that one connector and all my front audio ports work fine.
hope that helps.
LiquidImpulse
2,062
thanks for the reply, i think i just figured it out, there are these little black tab sort of things that(i guess) are adapters if you dont have the "pin" type connections, i removed them and the all-in-one audio connectors fits in perfectly, thanks for the reply sophalotjack.:)
