EVGA nF4 Motherboard Problem
MisterK
I have been told that the Jetway board and the EVGA board I have are pretty much the same thing, and Anandtech had reviewed the Jetway board and used OCZ Platinum Rev.2 RAM.
However, I have my EVGA board, a 7800GT, and the same OCZ Platinum Rev.2 RAM and the board is having massive problems with it. These are the problems I've noticed:
1. RAM is clocked at half of its rated speed (Its supposed to be 400mhz, not 200)
2. The timings are way off.
3. Its running on 2T command rate
4. Its not showing up in the right slots in CPU-z. I have it in slot 1 and 3 and it shows as being in 1 and 2.
If I try to change the mhz on the RAM to be 400 like it should be, it won't even boot up and I need to reset the BIOS.
If I change the command rate to 1T I can't boot into windows and just blue screen on the way in.
If I change timings the same thing happens.
Anyone have any ideas? I've tried other RAM on the board and it is extremely unstable and it will crash when I'm loading things like games.
Make sure you're looking at the right settins & the settings right. Sounds like you may be doing one helluva overclock all at once. DDR ram is figured x2, 200 x 2 = 400.
No, here is some of the text from the cpuz dump:
Memory Type DDR
Memory Size 1024 MBytes
Memory Frequency 100.5 MHz (CPU/22)
CAS# 2.5
RAS# to CAS# 2
RAS# Precharge 2
Cycle Time (tRAS) 5
Bank Cycle Time (tRC) 7
DRAM Idle Timer 16
Memory SPD
DIMM #1
General
Memory type DDR-SDRAM
Manufacturer (ID) (0000000000000000)
Size 512 MBytes
Max bandwidth PC3200 (200 MHz)
Part number
Manufacturing date Week 00/Year 00
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
Timings table
Frequency (MHz) 166 200
CAS# 2.5 3.0
RAS# to CAS# delay 3 3
RAS# Precharge 3 3
TRAS# 7 8
DIMM #2
General
Manufacturer (ID) OCZ (7F7F7F7FB0000000)
Size 512 MBytes
Part number OCZ4001024ELDCPER2
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
Timings table
Frequency (MHz) 200
CAS# 2.0
RAS# to CAS# delay 2
RAS# Precharge 3
TRAS# 5
I have mine in 1 and 3 and CPUID it shows 1 and 2.
I have the same board. My memory shows correct at 200 though. I am using 2 sticks of Patriot 512mb
I have the same problem, the RAM running on 2T command rate, if I change the command rate to 1T, no boot, does anyone know how to fix this? I have OCZ Gold VX PC4000, thanks.
