- Jan 16, 2005
- 127
- 0
- 0
My EVGA GTX 670 4GB finally arrived......yay!
1. I have an Asus P8Z77-V motherboard, and which PCI express slot do I install the card in? The motherboard manual leads me to believe it's the PCIe slot closest to the CPU, but doesn't this make everything really cramped?
2. I am really unsure on how to connect power to this card. The card has two 6-pin connection spots on it. I have a sweet Seasonic Modular Power Supply, that came with a cable which on one end connects to the computer power supply and the other end of the cable is splits to two separate connectors (8 pin, with 2 removable making a 6 pin usable). Each 6 pin is even labled 'PCIe'. Is it as simple as connecting the two 6 pins into the 6 pins on the EVGA card, and connect the other end (20 pin or so maybe?) to the GPU section of my Seasonic power supply?
Many thanks.
Many thanks.
