I need to buy a monitor and I was between the viewsonic vp930b and the vx2025wm but after reading how good is the vx2025wm and its reviews around here and other forums, maybe I'll end up ordering this soon.
There's also new release from Samsung that I was thinking would be a good rival to the vp930b, I'm referring to the 940bx, its contraste is 1000:1 with a response of 5 ms and is supossed to be on sale the end of this month.
I'm going to upgrade my video card just for the meantime before I make my major upgrade (motherboard, cpu and videocard) and since right now my budget is very limited
, I will be buying the eVGA GeForce 6200 with 128 mb 64bit found here:
http://www.newegg.com/Product/Product.asp?Item=N82E16814130008
And I was wondering if this card would be able to scale non widescreen content, like 4:3 movies or old games instead of stretching.
I know this card is not very good but will it be good enough to run the 1680 x 1050 resolution?
I have read that I will be to only plug it throug the vga connection since the DVI on this card does not support any resolution above 1600 x 1200.
Also, Is it worth it to buy the GeForce 6200 with 256 mb with the same specs (64bit, 4 pipelines) over the same card with 128 mb? Is it same? I have read that it would be same for this kind of card to have the 128mb or the 256mb.
I'd appreciate any help, please comment on this.
