- Mar 9, 2006
- 115
- 0
- 0
This is my first attempt at overclocking .. so some points might be absolutely dumb
So, I have a Dell xps 400 with the following:
Dual core 3Ghz P4 - 5494 CPU 3DMarks05
2 GB RAM
eVGA 7900GT CO - OC'd to 558MHz/871MHz - 7928 3DMarks05
Dell 2005FPW
Do these 3DMarks05 numbers look okay to you? I OCed using coolbits. Also, I have not applied any after-market cooler (Am using the factory copper cooler and fan). Since the same cooler is used in the super-clocked version, does this mean that I should expect a stable system at these clocks?
Will leaving the case open (I don't mind the noise) help in keeping the temperature down? I ran 3DMarks05, and checked the temperature afterwards .. it was at 47 degrees.
2 GB RAM
Dell 2005FPW
